Hi,
I have a Samsung LCD TV, Samsung Blue Ray, Apple TV 2, Logitech Harmony remote, and Denon AVR-2808CI. The rig was put together by an AV expert who is no longer in the biz. At some point I attempted some minor configuration changes, and since then nothing has worked. The setup is way to complicated for me, and the worst offender is the Denon. I've read the manual carefully, but even trying to reset to factory defaults does not work (at least not as described in the manual).
I realize I made a huge mistake in buying individual components. I should have bought an all-in-one like Bose, because I really don't want to have to learn anything at all about the technology. I really want something that "just works". But at this point, I've already spent a decent chunk of money, and I don't want to throw everything out and start over from scratch. Instead, I'm hoping to ditch the Harmony remote (i'm fine with using multiple remotes) and replace the Denon with something much simpler and much cheaper. I don't care if the quality is not as good as the Denon-- as long as it's easy to setup and use.
Any recommendations for a simple and cheap replacement for Denon? I want cheap because I see this as a stopgap solution. I"m hoping that Apple will come out with something so simple that even I can use it.
thanks for any suggestions.
-joe
-joe
