post #1 of 1
I need some individual door locks for some rooms in my house. Problem is, I can't find any that work with household door handles. Here is the type of the type I currently use:
www.amazon.com/Master-Lock-TUO0305-Privacy-Antique/dp/B000WS5J2Y/ref=sr_1_6?s=hardware&ie=UTF8&qid=1339130865&sr=1-6
Does anyone know where I could get an electronic lock that would fit this? Since it's just for indoors, I don't need deadbolts, and the quality doesn't need to be that good. Door strikes seemed like a good idea, but I doubt they would fit.
I'm not running a commercial automation system, so anything with terminals I can solder wires to would work fine. A handle is not required either, I already have one located elsewhere on the door.
