Hi,
I am building a home theater room and it is located below two bedrooms in my basement. I was wanting to sound proof the ceiling as much as possible. I was thinking of resilient channel with 2 layers of 1/2" drywall sandwiching green glue. I am not sure about the res channel as I have heard it doesnt help with low frequencies.
Should I skip the res channel as it wont be that effective?
Does light weight drywall have the same stc as the regular stuff?? (regular is getting harder to find around here)
It doesn't look like I can do hat channel and clips as I am in Canada and the channel they sell at local stores is too big to fit the standard clips.
Any suggestions are appreciated. I am not trying to "sound proof" just do my best with the limited budget I have.
Thanks, Tony
Thanks, Tony
