I just received an optical audio cable to connect my 42" Vizio TV to my Yamaha HTR-6040 receiver. I had it hooked up via the analog audio cables but because I currently have a 3.1 setup and plan to make it a 5.1 soon (I have the two other speakers, just haven't had the chance to hook them up yet and you really need to use digital audio to take advantage of a surround sound setup.
Anyway, it works fine using the analog audio out, but when I use the optical audio out there is no sound. When it goes through the auto setup it successfully finds and tests the left, right, and center channels.
I went through the user manual of the receiver and didn't find anything that I needed to do. I went through the menu on the TV and changed the digital audio from DTS to PCM and turned "Surround sound" from off to on. Still no sound.
Any ideas would be greatly appreciated.
