Originally Posted by scJohn
"ARC can convey Dolby Digital, DTS, and PCM, but none of the advanced codecs, such as Dolby Digital Plus, Dolby TrueHD, or DTS-HD." I am not 100% sure about DD+ getting down converted to DD.
IN other words ARC is not a true 'pass thru' feature.
ARC was designed to get audio from an internal turner (OTA antenna) or app running on the TV to be pushed 'upstream' thru the HDMI cable that is connected to a A/V receiver that also supports ARC. It is up to the manufacturers as to the level of audio support for for audio coming from the non ARC ports (HDMI1 and HDMI3). It seems that most manufactures will not pass thru but down convert audio coming from the non ARC port(s).
If you want to get full audio codec support for your XBox then plug your XBox HDMI cable into one of the 2 HDMI input ports on the back your bluray player.
I have switched over my HDMI cables. I removed my Xbox HDMI cable from port one of the TV. I moved it over to the BD receiver and tested the 5.1 sound. I does work. To be honest, I did not fully test last night the ARC method of 5.1 sound. I will try it this way as I had it before setup prior to this new switch. Now my other question I have. Since moving the HDMI cable from the TV to the BD receiver, will my Xbox have any loss of sound or picture quality since it is routed to the BD receiver instead of direct connection to the TV? Thanks.
