Originally Posted by jsl99
I am close to pulling the trigger on a 55" 7100 now that the price dropped again, but I am still afraid of the viewing angle. We will have the set in a room where my viewing angle will need to be decent (if not perfect) through a good 90 degrees. The ~20 degrees some are getting scares me, as it would make only one seat in the room (out of 6) a viewable angle (sofa directly across from tv, 2 chairs on the sides of the room). I have read here that decreasing contrast helps--but do you still have to watch this tv straight on? Thanks!
I'm no geometry expert, so i just measured 7' from the left side edge of my TV, then i backed up 10' and the picture was fine. I then moved forward to close that 10' gap, and the view started to lose quality. I'm thinking that 7' was acceptable, not preferable, but any closer would be an issue. I'm not sure of your actual seating dimensions from your TV, but maybe this will help some.
