AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXES7100 Thread.
Official Samsung UNXXES7100 Thread. - Page 90
post #2671 of 2849
Thanks man. I will. So your using the Nitra settings in Standard mode?
Is there any way to save those settings in the other source inputs or do they have to be changed manually?
BTW. Lovely bunch of people on this forum.
post #2672 of 2849
Originally Posted by James T View Post
If you want to be a little more adventurous Pirates Cove has some other setting a few posts after that.
My settings: http://www.avsforum.com/t/1414638/official-samsung-unxxes7100-thread/1950#post_22943484
Originally Posted by SteveOL View Post
What is Pirates Cove?
post #2673 of 2849
I started inputting your settings, Pirate Cove, but I got 3/4 of the way through the Movie setting in the TV source and it dawned on me that I was going to have to repeat the process for Movie, Standard, Dynamic and Natural for each of the TV sources and I thought STUFF THAT!! I'm far too lazy to go through all of that.
post #2674 of 2849
If anyone is interested in buying a Samsung UN46ES7100FXZA please pm me. Only 3 months old.
post #2675 of 2849
Hey guys,
I have a UN60ES7100 and am running the 1027 firmware. I have enjoyed the TV since I purchased it in February and had no complaints. However, yesterday the image seemed dim. At first I thought my eyes just hadn't adjusted from being outside and didn't give it too much thought. However, when I sat down to watch the game last night, the image was so dim that it looked as if I was wearing sun glasses.
I haven't messed with the calibration in a couple months since I found settings on this thread that I liked. I think I have them set to one of Pirate Cove's settings under the "Movie" mode. The problem continued even when I switched to Natural, Standard and Dynamic.
I checked to see if the Eco sensor thing was on, and it wasn't. I can't find any setting that is currently "on" that would cause the image to dim itself.
Has anyone else experienced anything like this? Any troubleshooting advice? Do I need to call Samsung? Update to the new Firmware?
Many thanks!
post #2676 of 2849
What you are describing is that your backlight isn't functioning. Try increasing you backlight to max at 20 to see if the screen gets brighter at all. If it does I would guess software, if nothing happens hardware could be the issue.
Other troubleshooting that you could do is reset the TV to factory specs, just make sure to write down your settings as you will lose everything.
If the above doesn't work call Samsung, but one of the first things they will have you do is update firmware, so you might as well do it at that point.
post #2677 of 2849
Hey guys quick question...
Is there ANY way to set the automotion plus to smooth or even activate it when your on gaming mode? I'm gaming mode looks great on video games... but I'd love to have the smooth effect with animation or games!
post #2678 of 2849
No way to use smoothing, it is disabled in game mode to reduce lag. If you aren't playing a first person shooter online then game mode shouldn't really be needed.
post #2679 of 2849
My kids play Guitar Hero on our 7100 and Game Mode makes all the difference with lag.
post #2680 of 2849
I've had some problems with my UA46ES7100 today.
Firstly, while watching, it started to turn itself off and on.
While waiting on the phone to Samsung customer help, I noticed the TV didn't pick up my home wireless anymore.
The Samsung person got me to turn the TV off and on (like an episode of The IT Crowd) and that seems to have rectified the off and on issue.
Unfortunately the wireless issue remains. Any advice?
post #2681 of 2849
The 1033 update is now available. I'll see how this update fares.
post #2682 of 2849
I've been watching the Tour de France. This set (7100) has the tour looking better than ever. Beautiful aerial shots of mountains and countryside along with the colorful cycling outfits.
post #2683 of 2849
1.This firmware is for TV Model(s):EH4500 / EH5300 / ES6100-7150
2.The version is 1033.1
3.This firmware update will improve the following:
- Resolves issue Netfilx doesn''t log on
- Support Verizon Apps
- Support Netflix 3.2 codec
- Resolves picture shaking and line noise on 1080p source.
- Supports Yahoo SyncPlus app..
- Resolves escaping issue while watching movie on VUDU.
- Resolves issue Cinemanow does not play certain title.
- Resolves compatibility issue with DLNA devices.
- Improves picture quality.
- Supports Samsung wireless audio dock (WAD) - * series ES6500 and above only
- Solves the problem closed caption does not show.
post #2684 of 2849
I have the latest firmware via USB. Made no difference to the wireless issue.
post #2685 of 2849
I had a problem on my set where I could not connect to the wireless. Powering off and on did not resolve the problem. I eventually got it to work by changing from my HDMI input to TV Signal. From there I was able to see and configure the wireless.
When I returned to the HDMI input the wireless was still working and could once again see my router.
Might be worth a try...
post #2686 of 2849
Hmm, I don't think I saw any difference in picture quality...
post #2687 of 2849
I am having problems with my wifi also. A wired connection works fine but now i cannot connect via wifi. I try to scan and it does not pick up anything.
I am on 1014 firmware. I will try updating and see if that helps. I tried resetting and that did not work.
EDIT: updated to 1033 and it seems to be working after trying to set up wifi a couple of times. I just happened to click on wifi direct as it was greyed out for some reason. After it told me it was not available, my wifi started working.
Edited by DMP87 - 7/11/13 at 7:06pm
post #2688 of 2849
On the Samsung website there is a firmware download 1034. Anybody know what it does?
post #2689 of 2849
Does anyone have any advice on updating firmware from 1025 to 1031? I definitely saw improvements in picture quality when I updated to 1025 (I forget what the prior version is), but I know some folks have had negative experiences with upgrades. Any thoughts? Thanks!
post #2690 of 2849
Well, looks like 1031 has been replaced by 1034, so I'll ask the same question regarding upgrading from 1025 to 1034. Thanks!
post #2691 of 2849
I have version 1017 and have yet connected my tv to online.going to this weekend but worried about the firmware issues. It seems 1027 was a good version. Does anyone have 1027 still on usb? i would like to get copy. Afraid of the new 134.2
post #2692 of 2849
Wow. 2 updates in 2 weeks
The version is 1034.2
- Support Samsung Link
post #2693 of 2849
i have not had any issues with any of the updates ....(yet) Going to update to 1034.2 today.
post #2694 of 2849
I recently setup my UN55ES7100, and it downloaded the 1033 updated, I see that the newest one on the website is 1034, tried doing the update from USB, but it says no update files found. Has anyone successfully updated from 1033 to 1034? Or is it in fact the same file and that is why it isn't allowing me to update.
P.S. - The online update mode doesn't find any files either.
Thanks in advanced!
I've been lurking around these forums lately, I'm soon to get my first apartment and I will be able to really start my journey into Home Theater enthusiasm :P
post #2695 of 2849
Nvm when I got home I placed the folder on an empty flashdrive and it updated fine.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
post #2696 of 2849
I think this new 1034 update is the first update I have ever done on a Samsung TV ( I have had 3 ) that it actually may have helped the overall picture quality.
post #2697 of 2849
Awesome! Glad its working out well for you. This is my first high end type TV, and so far I am loving it, I was watching Toy Story last night and it looked amazing. I haven't gotten use to the fully calibrated look of the TV, especially when watching animated films, so right now I have been using a mashup of what looks good to my eye, and what the calibration disc says I should have ;P Once my TV stand comes in and I can prop the TV up correctly I will have to re-calibrate and see how it goes smile.gif
post #2698 of 2849
I found moving from FW 1027 to FW1033 should a noticeable difference in better PQ. Seems like the colors are a bit brighter. I'll post my calibration numbers tonight that I got from when Best Buy did my free calibration. I'll probably update to FW 1034 as well.
post #2699 of 2849
That would be awesome! Give as much detail as possible smile.gif I know copying settings isn't ideal, but I do like using them as reference.
Much appreciated!
post #2700 of 2849
it's funny how every update ' 'Improves picture quality"
I'm still on 1025 ....
