Originally Posted by vipergtsrz
Hello everyone,
I just got my 7100 last night from Costco, and after hooking it up, I can't seem to find out how to change the picture settings when I have it hooked up to my PC.
My PC is basically the only thing I use with my TV. I have my over the air antenna going to my PC with Windows Media Center and I play all my DVDs and BluRays off of it as well.
The picture that I get from the PC on this new TV is really dull and isn't colorful at all.
Whenever I try to adjust picture settings, nothing is available. When I click on something, it says something like "You can't adjust this property when the TV is connected to a PC".
Why in the heck would they limit the picture settings that I can adjust only because I have the TV plugged into the PC?
Please tell me there is a way around this. If I can't calibrate my TV's picture when it's hooked up to my PC, I'll have to take it back and get a TV that will let me do it.
So far, I'm pretty disappointed.
Hello everyone,
It won't really matter what LED you buy because your HTPC CMS will override the TVs.
You should look into disabling on your video card what the HTPC is sending to the samsung to blank out your CMS.
I don't remember what exactly it was but I'm sure if you post in the calibration forum what your issue is someone will tell you exactly where to go in your video card settings to send a raw tunable signal to the TV.
