AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › No RCA outputs on dta box?
post #1 of 8
Sure this question has been asked before but no luck with searches. TIA for any input.
Local cable provider switching to all digital and provided a couple of Pace DTA boxes that work fine with old TVs. Here is the problem... Am building vintage stereo system that I would like to run the analog audividioo through as would sound better than TV speakers (duh!) Problem lies in available connections.
DTA has only RG6 coax in/out (digital/analog chnl 3/4) TV (Phillips TS2746C)
has RG6 in as well as RCA audio and video in, no audio out. DVD/VCR tunerless recorder/player (Magnavox DV225MG9) has RCA inputs only, no RG6.
Not interested in recording off cable so video signal is moot but would like to know if there is a way (short of buying dedicated junk vcr. No more room) to grab audio output off RG6 analog output from the dta ?
Probably simple or not possible as is the usual case. Tks again for any input
Capt David
post #2 of 8
What you are looking for is called a Demodulator. Not nearly as common as a modulator but they can be found.
Here is a quick Google search
Looks like the best deals are used head-end equipment on E-bay.
post #3 of 8
Thanks..... for the price, will probably just by a junk vcr at the local thrift store, split the output from the DAT and rip the audio output that way
Thanks again for the input
Capt David
post #4 of 8
You might request a cable box with the A/V outputs. They do have one that's nearly as basic as the DTA.
post #5 of 8
The audio from an RF-only DTA is monaural only, I am 99% sure.
post #6 of 8
You can safely add the other 1%
post #7 of 8
If your TV has audio out connect that to your receiver.
post #8 of 8
Originally Posted by captdavid View Post
... TV (Phillips TS2746C)
  Back to Forum: Cable, Digital Cable - Non-HDTV
