AVS › AVS Forum › 3D Central › 3D Displays › RF / Bluetooth 3D Glasses compatibility thread.
RF / Bluetooth 3D Glasses compatibility thread. - Page 2
post #31 of 37
I'm exactly in the same situation as you guys: bought 2 pairs of SSG-4100 3D glasses for my Panasonic GT30, just to find out that my TV is infrared after all...
There has to be a lot of people in the same situation, wrong glasses for their tv's or vice-versa.
Surely there must be some kind of device that makes the conversion of infrared signal to bluetooth. Perhaps through software in a PC (using a usb IRDA adapter and a usb Bluetooth adapter, and some software makes the translation)?
post #32 of 37
post #33 of 37
I just installed both a Panasonic TC-P65VT50 plasma (2012, uses Bluetooth glasses) and a Panasonic PT-AE8000U projector (2012, uses IR glasses). I have an older P54VT25 (2010, uses IR glasses) which is now in the master bedroom. I also have seven pairs of IR glasses (one TY-EW3D10U that came with the TV and six TY-EW3D2MU that came with the Avatar starter kits). The glasses work with the AE8000U just fine. I know that the newer TY-EW3D3MU glasses are a bit lighter... don't know if they have any better picture quality. Amazon.com is out of stock on the Bluetooth glasses TY-ER3D4MU... heard they were once under $50 there, but now the cheapest seems to be $80 at Best Buy.
So, I, like a few other posters here, am also on the hunt for a way to make a Bluetooth transmitting TV also transmit IR. The Panasonic projectors can use a trigger output to run a ET-TRM110 external IR emitter. I wonder if any of the 50 series TVs (VT50, GT50, ST50, etc) have a way to drive the emitter.
Or, alternately, a device that will sync with the Bluetooth signal from the plasma (like a pair of newer Bluetooth glasses would) and then work as an IR emitter so that any number of old style IR glasses could work with a Bluetooth style TV. We cannot be the only ones in the world that are thinking about a solution to this problem. If I don't find a solution soon, it might be time to pair up with my friend that does electronics hacking projects and buy a pair of the Bluetooth glasses like the Samsung SSG-5100GB on Amazon.com for $20, and hack them for their components and turn it into an IR emitter for the older style glasses. This would also allow people to get around the 7 pairs of glasses limitation that seems to come with the newer Bluetooth televisions. I'd rather just buy something off the shelf, or read about someone else's hacking project and put the components together myself if needed. Has anyone looked into this yet?
Edited by jch2 - 3/18/13 at 12:20am
post #34 of 37
Originally Posted by racprops View Post
The Quantum G5 G7 glasses look a little girly to me...
Like 50s sun glasses..
Rich
After hours of stress that led me to this forum, the G5 glasses DO NOT work with the GT-50!!!!!!!!!!!!! Ran to BB and got some 4100s and all my grief was over...sigh....
post #35 of 37
I have a Mitsubishi 842 series RF and have had luck with the SSG-4100 and also the 3Active 3D glasses for my 842 series. I will say that the SSG-4100's sync quicker than my 3Actives. Both work really well.
post #36 of 37
Has anyone tried using EX105BT emitter with Optoma HD33 (or other 3D VESA compatible) projector? I assume the emitter is the same one XPand has announced this year:
http://www.xpand.me/products/radio-frequency-emitter/
They have also the DLPLink to 3D VESA converter (mainly for classroom use though):
http://www.xpand.me/products/white-flash-converter/
AFAIK there doesn't exist any RF to IR converters. XPAND has some RF Dongle but it's only for their Youniversal glasses:
http://www.xpand.me/products/youniversal-3d-glasses/technology/
post #37 of 37
Thinking of buying the SAMSUNG SSG-4100GB glasses for my Panasonic xtl55dt50, they will work, right?
Also, what is the difference between these cheaper samsung glasses and more expensive pairs e.g. panasonic glasses. ?
  Back to Forum: 3D Displays
