AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic ST50 image retention, please help!
Panasonic ST50 image retention, please help! - Page 26
post #751 of 756
Originally Posted by Cuda1169 View Post
The scrolling bar never works for me except to point out where exactly my IR is. Try a pixel flipper with the contrast dialed up. Worth a try, since the scrolling bar has not worked for you. Also, how old is your panel. If you panel is still very young, the IR may clear up on its own after a long while.
why is pixel flipper better? also does the scrolling bar have a time limit? i tried the scrolling bar for 40 min and didnt completely take care of it. The IR is from long ago it might seem.
edit: i just checked and only North american version has time limit, this explains why mine doesnt. Ive been thinking just to see if regular movie can do the trick, would a cartoon be better though?
Edited by dioxholster - 11/1/13 at 12:57am
post #752 of 756
Originally Posted by superslav View Post
Panel is 2 weeks old, sent to Panasonic for to get checked before getting a refund, Im getting a LED TV, not taking any chances with plasma anymore.
you shouldnt have to be bothered by babying your TV. if you want to play a game for a few hours... you should be able to without having to jump through all kinds of hoops to make sure your screen isnt ruined.
Panasonic is now halting all plasma display manufacturing and cancelling all future lines starting in december. its about time plasma went away and we get some better technology that doesnt require a life plan in order to use it.
post #753 of 756
I watch whatever I want for as long as I want and don't have IR issues. If you are hysterical about it then Plasma probably isnt for you.
post #754 of 756
OLED is worse than plasma for image retention. so no the problem isnt going away.
post #755 of 756
Well I've tried all of the suggestions offered here. Scrolling Bar and Pixel Flipper and I can still see the faint IR of the MSNBC bar and logo in the upper portion of my brand new television after only buying this TV in July. With time, will it go away? I hope so. Cause I really love this Plasma TV, but my eyes are often distracted by the IR of that stupid MSNBC logo bar. And Panasonic is offering ABSOLUTELY NOTHING but the same as everyone here. I want this TV replace. Has any else here had a TV replaced by Panasonic suffering from the same issue? Message me please. And if you've had any success with the same issue. Please let me know.
post #756 of 756
better speakers, dual core processor and smart evolution expansion slot which may be valuable in the future. Noboby knows yet, but i could imagine for example 48fps playback etc. new standars could be upgraded with that.
1bHk
