AVS › AVS Forum › Blu-ray & HD DVD › HDTV Software Media Discussion › Buying Blu Ray Discs, newbie ques:
post #1 of 9
Ordering my First BD player. When I go about purchasing or renting BD's what do I look for in referrence to How it's recorded? I'm non-tech, but I seemed to have gleaned from the forums that the actual discs can vary in quality, some because their older, or just a manufacturers decision, and I want to at least have a way of identifying a disc that is better quality. Perhaps its indicated on the actual BD Box, etc.
post #2 of 9
You can only find out by reading reviews. The manufacturers really aren't interested in telling you when their workmanship is shoddy.
Ratings of picture quality can be found in http://www.avsforum.com/t/1168342/the-new-pq-tier-thread-for-blu-ray-rankings
Ratings of audio quality can be found in http://www.avsforum.com/t/1190265/new-audio-tier-thread
post #3 of 9
Thanks, I get what you mean. I was thinking when I see an older BD, it might be designated as a "re mastered" or some identification that it didn't start as a Blu Ray disc. Or even a referrence to a discs technical attributes, so to speak. Kind of like when I used to buy Telarc cd's cause of the better audio recording.
Thanks for the link, I will check the reviews and info. You've helped me quite a bit as I've been posting lately, really appreciate your expertise. I went ahead and splurged for the Panny 500, should get it today. Can't wait to listen to my cd's, then build a moderately priced surround sound system, then really enjoy BD movies since I've never seen a BD at home. Fun!
post #4 of 9
Oh, quick update. The link you gave is really great, does speak to some of my "quality to look for" concerns. Leave to AVS forums to inform!
post #5 of 9
You're very welcome!
post #6 of 9
You may want to check out reviews here at AVS Reviews, Blu-ray.COM and High-Def Digest.
post #7 of 9
Thanks for the heads up Wendell, I will. Nice feature here on the AVS.
post #8 of 9
Also, Home Theater Magazine does monthly reviews of all the popular BD releases.
Ian
post #9 of 9
Correct, I subscribe to Home Theater Magazine and Sound & Vision print magazines. Both have Blu-ray reviews. Wide Screen Review used to have extensive Blu-ray reviews but I have let my subscription lapse so can not speak for current versions.
  Back to Forum: HDTV Software Media Discussion
