AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › size or quality? e550 vs gt50
post #1 of 9
Alright I know that the GT50 is a better tv then the e550. However I can choose to get 64inch e550 or the 60 inch gt50. (its a points thing through work). Would you sacrifice size or quality? Just wanting some opinions here. Thanks!
post #2 of 9
Found a lot about this topic here and the consensus seems to weigh in the size favor however GT50 seems to be a lot better TV then the e550? I am sitting about 10 feet away.
post #3 of 9
Both sets have their flaws for sure.
I owned the Samsung PN51E550 and returned it due to auto brightness adjustments during hockey, random flickering during sports and annoying buzz. I wanted to like the Samsung because overall the sports looked pretty darn good except for the Hockey issues. So after returning the Samsung, I went with the Panny GT50 and received it last Friday, the bezel is so much nicer looking compared to the Samsung, 4 HDMI slots instead of 3, 3 USB slots, SD card, WiFi and 3D (no glasses though). I have only had the set a mere 2 1/2 days and so far out of the box, blu ray movies are very nice looking, with a good amount of tweaking options but the HD sports looked grainy and washed out, I was using the standard picture mode; some folks reached out and gave me some tips so I will be putting it to the test against tonight's cup finals match.
In my opinion, go with Quality.
post #4 of 9
Thats not really a far comparison.
Since the E550 is Samsung's lower end model and the GT50 is a higher end Panasonic model.
The Panasonic UT50 models are directly comparable feature-wise to the E550.
The GT50 is more like the higher end Samsung E7000 models.
post #5 of 9
I am not trying to compare the 2 TV's what I am saying is I can get the 64 inch E550 for the same as the 60 inch GT50. So should I get the bigger one or is the GT that much better where I should get the 60 inch?
post #6 of 9
Pick Size unless your option is a crappy tv. The E550 will be perfect, I think! Enjoy
post #7 of 9
If you watch mostly hd and 3d in dark room then take Sammy, but if you are in bright room take Panny.
post #8 of 9
Quality over size any day. What's the point of having a bigger screen if you can see every flaw. I would go for the GT
post #9 of 9
Exactly what flaws E550 has? Im sure it is pretty similar to more expensive sammys which rivals panasonics. Only flaw is that this doesnt have ar-filter, but in a dark room thats not an issue.
