AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › How to test a used Niles ZR-4630
post #1 of 2
I found a bargain on a Niles ZR-4630 and wanted to test it out before I buy. It only comes with a Niles R-4 remote, no other accessories .Once I connect a speaker to Zone 1, what key(s) on the reomote activates the sound for source 2 (I have a computer that plays music connected to source 2).
Thanks in advance.
post #2 of 2
Well unless you have the Nikes Keypads, the unit will not do you much good. The remote is used to do 2 things: 1, Program the system by flashing the niles remote, such as enter, and then the OEM remote for cable let's say. 2, it will work if your keypad has an ir sensor to aim at with the Niles remote. Otherwise, the unit is a paperweight. You cannot use any other keypad with it.
  Back to Forum: Home A/V Distribution
