$900 (USD) or Best Offer
send a PM to take the next step.For Sale:
BNIB Klipsch SW-310 Sub and 2 G-12 Speakers
Will Ship To: CONUS
I have a brand new in box Klipsch SW-310 subwoofer (retail: $750) that I bought and then changed my mind on what I wanted to do. Purchased from authorized retailer. I also have 2 G-12 flat panel speakers from Klipsch, still in the box, ordered from the same website.
SW-310 Specs:
AMPLIFIER: BASH® Digital Hybrid
AMPLIFIER POWER: FTC Rated Power: 400 watts continuous @ <2% THD / Dynamic Power*: 900 watts
BUILT FROM: 2010
DEPTH: 13" (33cm)
DRIVE COMPONENTS: 10" (25.4cm) Active / Dual 10" Passive non-resonant Woven Fiberglass drivers
ENCLOSURE TYPE: Bass-reflex via dual side-firing passive radiators
EXPORT VOLTAGE: NA, EU
FINISHES: Black satin
FREQUENCY RESPONSE: 24Hz-120Hz ± 3dB
HEIGHT: 13" (33cm)
INPUTS: L/R Line-level RCA jacks, WA port
MAX ACOUSTIC OUTPUT: 116dB @ 30Hz
OUTPUTS: None
SENSITIVITY: 106dB @ 40Hz
VOLTAGE: 100-120V / 220-240V~50/60Hz 4A (Auto-voltage switching) with 1 Watt standby
WEIGHT: 35lbs (15.9kg)
WIDTH: 13" (33cm)
G-12 Specs:
BUILT FROM: 2011
CROSSOVER FREQUENCY: 2200Hz
DIMENSIONS (without base): 12" (30.48 cm) H x 6" (15.24 cm) W x 2.4" (6.10 cm) D
FINISH: High Gloss Black
FREQUENCY RESPONSE: 69Hz - 24kHz +/- 3dB
HIGH FREQUENCY DRIVER: 1" (2.54 cm) Titanium diaphragm compression driver mated to 90° x 90° square Tractrix Horn
INPUTS: Single wire 5-way binding posts
LOW FREQUENCY DRIVER: 3.5" (8.89 cm) long-throw IMG woofer
MOUNTING: Dual keyhole
NOMINAL IMPEDANCE: 8 Ohms compatible
POWER HANDLING: 50W RMS / 200W Peak
SENSITIVITY: 91 dB @ 2.83 V / 1 m
WEIGHT: 3.75 lbs (1.7kg) each
Looking for $900 picked up in Rochester NY, or $900 + shipping OBO to the CONUS. I can take pics of the actual boxes, but they're not that exciting.
SW-310 Specs:
BUILT FROM: 2010
DEPTH: 13" (33cm)
HEIGHT: 13" (33cm)
OUTPUTS: None
WIDTH: 13" (33cm)
G-12 Specs:
BUILT FROM: 2011
