AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Help pick/suggest a new AVR
post #1 of 11
So here’s the deal. I have a budget of between 500-700 for a new to me receiver. Doesn’t have to be NIB, but does need a warranty of some sort (so refurbs are ok). I would prefer something around the 500 dollar mark (so I can get some new headphones with the leftover) but I am willing to blow it all on the receiver if its justified.
Here is what I need:
1. More than 4 HDMI 1.4 ports
2. Upscale composite video (Xbox, SNES, Nintendo, etc) and send over HDMI
3. Pre-outs for at least 7 channels. Pre-outs for 7 + heights/wides would be nice but not required
4. Ability to drive one set of small bookshelf 4 ohm speakers if no pre-outs for heights/wides
5. EQ in the form of Audyssey XT or higher OR ARC
Here is my current setup:
TV: Panasonic 60” TC-P60ST30 Plasma
Receiver: Integra DTR 5.9
Amps: Carver TFM-35 (driving front left/right), Carver AV-705x (driving center and surrounds)
Fronts: Polk LSi 15
Center: Polk LSiC
Surrounds : Polk LSi F /x
Sources: Samsung BDP-1600, Xbox 360, Pioneer Laserdisc, Super Nintendo, N64, Uverse DVR
I will be adding more vintage consoles, but building a rolling console center so I can move them close to the person playing them (since old console's are not wireless). The console center will have a switch of some sort and be connected to just one input on the reciever.
I have on my short list the following receivers:
Onkyo TX-NR709
Onkyo TX-NR809
Anthem MRX-300 (assuming I can get a deal on it and while its only got 4 HDMI for ARC I am willing to make an exception)
Let me know if I am overlooking any you think are contenders. Thanks!
post #2 of 11
I believe the 709 is the cheapest AVR you can get with both preouts and XT, so that's the one I would pick. The best part about going with a lower priced AVR is you wont feel bad in a few years when you want to upgrade again. Add the 3 or 5 year extended warranty from A4less and you'd be covered.
http://www.accessories4less.com/make-a-store/item/ONKTXNR709/Onkyo-TX-NR709-7.2-Channel-3-D-Ready-Network-A/V-Receiver/1.html#!warranties
post #3 of 11
Yeah the reason the 809 is on there is specifically because its got a MUCH better amp than the 709 and if I am driving one set of 4 ohm speakers off the Onkyo, I want to make sure its got the power to do so decently. That and lets be honest, it looks better than the 709 smile.gif.
I wouldnt purchase the warranty from accessories4less. In July (when the purchase will be made) it might still be possible to get the 809 or 709 NIB for around 500. I know the 709 online is NIB for like 550.
Any other AVR's I should be looking at from Accessories4less? I really wish the darned 3009 would come down considerably in price as thats the one I really want as its got XT32, but I dont have the coin and cant afford to keep waiting smile.gif.
post #4 of 11
I dont think the amp section is relevant, pretty much any AVR could drive 4 ohm surrounds by themselves. If you dont feel comfortable with the 709, then your decision is made. The 3312 or 3311 would be another to consider from A4less.
post #5 of 11
Actually just noticed the 709 doesn't have a removable power-cord, which is something I kinda wanted, so the 809 is now top of the list. Both those Denon's are contenders so I will have to look them up for sure.
post #6 of 11
If you go to $799 you can get a new marantz 6006. You may be able to get it cheaper if you shop around. I think it's step up from the denon and onkyo's you're looking at.
post #7 of 11
The Denon 3312CI and the Marantz 6006 are basically the same model with almost identical internal components.
post #8 of 11
I cant really step up above budget on this. I will have 700 total to spend and thats it. I am seriously looking at the Onkyo 809 and the 3312CI. I like the Onkyo's weight since it should mean its got a beefier amp section.
I also really dont like the display on the Marantz 6006 since its a PITA to tell volume from far away. I really like the bigger screen with info the Denon's, Onkyo's and even Pioneer's have....
I also might have a Pioneer SC-61 in my price range. Any thoughts on that AVR
post #9 of 11
I know. The 6006 has more plugs in the back, but basically the same thing. I got an email this morning. The 3312 is on sale on amazon for $550.
post #10 of 11
I wouldn't sleep on this deal. When I got my 3311 around that price last year they were not on Amazon for long.
post #11 of 11
Have to sleep on any deals till cash is in hand in the middle of July frown.gif
