AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Search this forum button labels unreadable
post #1 of 3
When I click on Search this Forum, there are two buttons below the search text. I'm not sure what the exact colors are, but there's almost no contrast between the background (dark grey?) and the label text (black or very dark blue?), so they're unreadable unless I highlight them with the mouse. Can this color scheme be fixed?
post #2 of 3
Hi,
Thanks for the report. These have been slated for a fix.
post #3 of 3
I just found the skin preferences and changed from AVS Black to AVS Default, and now the buttons are readable. But I think you should make the colors in that pop-up adjust based on the skin, so it's readable in either version.
And now I see that this has already been reported in another thread http://www.avsforum.com/t/1414078/black-skin-issue/
  Back to Forum: Forum Operations Center
