AVS › AVS Forum › A/V Control & Automation › Remote Control Area › is Harmony700 capable of mouse right click functions
post #1 of 10
Harmony 700 w/ 7.7 software controlling W7MC
would like to program a sequence including hard buttons, soft buttons and right click mouse functions is this possiable?
like for stop play of W7MC recorded TV
1.stop hard button
2.minimize window soft button Win+Down: Restore / Minimize
3.at desktop right click mouse function
4.personlize
5.preview screen saver.
edit if the Harmony is'nt capable of this is a actualle WMC remote capable? then used for a raw learn to the Harmony?
Thanks STB
post #2 of 10
post #3 of 10
is this Logitechs termonogoly for right mouse right and left click
Win+Left: Snap to left
Win+Right: Snap to right
because I have these functions on the soft keys?
if not what is logitech calling the mouse right and left click functions?
Thanks STB
post #4 of 10
Thanks STB
No, that makes a window connect to either the left or right of the screen. In Win7 drag a window to the left or right and it will snap into place and take up half the screen.
There are more commands in the WMC SE database than what is listed in that post. Mouse control is a few posts down. Keep reading or just try it out.
post #5 of 10
Bryan I have been reading and reading
all I see on a mouse function is direction.
I can't try anything becauce I don't have a IR reciever yet no point in even getting one if I can't program the Harmony the way I'd like to.
post #6 of 10
If you go into the MCE SE device on the Harmony you will probably see the mouse button codes.
post #7 of 10
excellent Bryan I now see in PC device mouse right & left.
from what Iread I Just assummed that was direction.
now after a right mouse is it possiable to clich win7 personalize then preview screen saver?
thanks STB
post #8 of 10
Probably not with a Harmony given its 5 step macro limit. You'll need some other trick to run the screen saver. A program like AutoHotKey or EventGhost would take care of that. You would just map a button to perform the macro or directly launch the screensaver.exe (or whatever it is called).
post #9 of 10
post #10 of 10
Bryan I'll check into AutoHotKey or EventGhost.
I'm leaning toward this. for it's IR and for learning to the Harmony
http://www.ebay.com/itm/Wireless-Window-Media-Center-MCE-PC-IR-Remote-Control?item=280456385990&cmd=ViewItem&_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D2%26po%3DLVI%26ps%3D63%26clkid%3D9152819985320173414
Thanks STB
Why would you be "learning to the Harmony"? The codes are already in the database.
This is what is typically recommended
http://www.ebay.com/itm/New-HP-USB-MCE-IR-Wireless-Receiver-Windows-7-Vista-/251087367827?pt=US_Remote_Controls_Pointers&hash=item3a75f92e93
  Back to Forum: Remote Control Area
