AVS › AVS Forum › A/V Control & Automation › Home Automation › In-wall doc for iPod touch
post #1 of 3
Hi gentlemen,
Just need a inwall charger dock for ipod touch 3 or 4.Could you give me some advice? by the way,iport cm-100 or 200 is a little expensive,so I want to buy some charger only dock.
thx
John
post #2 of 3
Vidabox makes 'remote' ipad chargers/extenders (moves power source 100 feet away) - could probably be used for iTouch as well.
post #3 of 3
If the cm100 is too expensive that I can't really think of anything... It's about the cheapest.
  Back to Forum: Home Automation
