Looking at the following components for my new build, not sure of what PSU I should go with.
CPU: i5-3570K w/ Cooler Master Hyper 212 EVO
Mobo: ASRock Z77 Extreme6
RAM: G.Skill Ripjaws 8GB (2x4GB) DDR3 1600 (may end up with 2 more 2GB sticks)
GPU: GTX 670 2GB
HDD: SAMSUNG Spinpoint F3 1TB 7200 RPM
CD/DVD: ASUS SATA 24X Burner
Case: Xigmatek Midgard II (has 2 80mm fans)
PSU: ???
Not sure what wattage I'd need in a PSU with the above. Also, what if I were to SLI the GPU? Or if I add any additional case fans?
Any PSU recommendations, specific or general, are appreciated. Don't know what brands to favor/avoid. Also, if anyone has suggestions for the actual PC components, you can throw those my way as well.
Thanks in advance.
Edited by yalikedags - 6/20/12 at 9:04am
GPU: GTX 670 2GB
PSU: ???
Thanks in advance.
