AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Fibe tv, sound comes on 1-2 second after changing channel
post #1 of 2
I have Fibe Bell tv and when I had cable, there was no lag on the sound when changing channels. Then I switched to Fibetv and since then there's a lag. My nephew has a Yamaha receiver and has no lag when changing channels. I even upgraded the HDMI to a network Hdmi and no luck.
Anyone familiar with this problem, Here in Canada Fibe tv comes through the phone line( internet) I don't know what's called else where.
thanks
post #2 of 2
FibeTV is basically IPTV.
Do you and your nephew have the same receiver?
The lag is probably from your receiver needing time to "lock" onto the incoming audio signal.
