AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › Can't see video when FF or REW VHS
post #1 of 3
I have a Denon 1909 receiver.
Tried different cables, different VCRs—problem persists. I think it has to do with one of my settings on the Denon. I've tried everything.
post #2 of 3
The picture goes pretty unstable when in FF or REW and your Denon obviously doesn't have the same tolerance for distortion that good old CRTs did. Pretty good chance a modern Flat Panel TV can't handle it either.
post #3 of 3
I should've stated that...
- It's worked perfectly fine for years with both HD sets I've had.
- Problem only started after I moved residences and re-set up everything. So there must be a setting that I set wrong.
- Not only video disappears when FF and REW, but also when I hit PAUSE, or when tape tracking gets a little off, but picture returns when tracking is 100%.
  Back to Forum: Cable, Digital Cable - Non-HDTV
