AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Best TV For $1,000
Best TV For $1,000
post #1 of 5
I'm currently in the market for a new TV but only have about $1,000 to spend. I haven't kept up with TVs latley so what is the best TV I can buy right now.with that budget.in terms of picture and sound?
post #2 of 5
can anyone help me?
post #3 of 5
post #4 of 5
Aren't plasmas dangerous to use for gaming and HTPC setups with potential for nasty burn in due to stuff like desktop icons not moving and game UIs being static?
post #5 of 5
There are reports of IR still being an issue. Burn is a rare concept these days, but is a possibility in extreme cases. If you plan on using HTPC a lot than LCD/LED would be the way to go.
For general gaming and light HTPC use (no more than a few hours sitting on same screen) plasma would be a viable option. You would get the best gaming/picture setup this way.
LCD/LED cannot touch ms rates of lower end plasmas cannot be touched by LCD/LED.
If you are interested in LCD/LED for gaming/blacks your best options will be:
-LG LM7600 (lag could be noticable) 30-40ms
-Panny Et5 or e50 (Great ms for a LCD) 25-30ms
-Toshiba 6200u (reports seem to be good on ms lag but no confirmations from reviews/tests)
-Samsung es6100 or 6500 (again no confirmed tests for lag)
