AVS › AVS Forum › Video Components › Home Theater Computers › Remote question ?
Remote question ?
post #1 of 5
Hi,
I woul like to use my laptop with a projector, and be able to control the laptop's mediaplayer with a remote but the main thing is the laptop won't be in sight...
So my question would be, do i need a RF remote or can i control my laptop with a IR remote too ?
Thanks in advance.
And thanks for welcoming me too.
post #2 of 5
Not in sight would dictate an RF-based solution unless you augment an IR remote with an RF repeater kit (Rabbit) or a hardwired IR engine like the Xantech.
post #3 of 5
Both solutions seems complicated... apart from the rf-based solution.
What about Bluetooth technology ? Like the TiVo Slide ? It should work out of the box too like the rf-based solution ?
Thanks for the help, again.
post #4 of 5
A smart phone and Mobile Mouse or similar app works very well over wi-fi without buying any additional devices.
post #5 of 5
An alternative is to install Event Ghost and use the web server plugin. Then you can control your apps from any device using a web browser.
