Originally Posted by
gellyÂ
Have you tried the preset settings? i tried calibrating it using the recommended setting for "expert 1" and found in most instances the preset was better.
Did you double check your inputs? Are you cables compromised? How do you have your STB and LG hooked up?
Thanks gelly!
I have Dish Network, so I connect the HDMI from Dish to the LG HDMI1. I have a Sony 3D BD player that I connected to HDMI 2. That's all that are connected to the TV. This is the same as how I connected on my old Samsung TV.
I've also tried the settings as recommended for the LM9600 as shown in this article below (I saved this in Expert2):
This one for the LM9600 has much more settings and includes different settings for both 2D and 3D.
http://www.hometheater.com/content/lg-55lm9600-3d-lcd-hdtv-settings.
The other set-up I've tried (see below) was for the LM8600 and I saved that in Expert1 (I use the same set-up for both 2D and 3D):
http://reviews.lcdtvbuyingguide.com/lg-lcd-tv/lg-55lm8600-picture-settings.html
Both set-ups seem to prefer the color temperature to be set to "warm" but I find it to give a pinkish/yellowish look to the picture. I much prefer the "cool" temperature setting which gives a brighter picture but still not as good as I like it to be (or what I have recalled seeing at the different stores).
So on both set-ups from the above links, I've changed the settings to "cool" temperature but kept the other settings. The picture still seems to be "faded" or "pale", not a vey vivid picture.
Do you have the LED local dimming turned on? The 2 settings above has one set (LM8600) to off but the other (LM9600) to set to high, but I really don't see much difference between both settings (LED dimming on or off) or difference betweenExpert1 and Expert2 with the recommended settings from the above links.
Also, is there a way to change the timer on the magic control before it goes to a sleep mode? It seems to default to about 5 sec so I constantly have to wake it as I'm doing the picture settings.
