I purchased an LG 60PZ750 from Sears several months ago. I have noticed during very bright or dark scenes, there is a luminous green bar that shows up about 2/3 towards the left side. It is vertical, and runs the entire height of the display. During regular scenes it's not noticeable. I'm concerned the problem will grow worse over time.
Do you have any idea what may be causing this, and what I can do about it?
Thank you
Thank you
