Yes you CAN hear jitter!
And it's bad for the sound of your main stereo system.
It's hot here in Chicago today; 88F in the house (fans on!); outside it's 92F (down from 94F an hour ago).
So I thought: don't run any extra gear today; copied a bunch of stereo .flac files (16/44.1 quality rips from my best CD discs) to my trusty external USB HDD.
Played it via my new 2012 Panasonic DMP BDT500 blu-ray player with these combos:
1. Using the DAC(s) inside the BDT500 player; output via the BDT500's rear 7.1 RCA outs via two RCA cables (length not that important as it's an analog signal being carried).
2. Using an external Bel Canto DAC3 via a single 7' digital coax cable for the signal in S/PDIF format.
3. Using an external Benchmark DAC1/HDR via a single 7' digital coax cable for the signal in S/PDIF format.
4. Using same external Benchmark DAC1/HDR via a single 2' digital coax cable for the signal in S/PDIF format.
My impressions/opinions:
1. The BDT500 player is one sweet player for top sound quality, both figuratively and literally.
2. My external Bel Canto DAC3 has a slight "solid state" sound; noticeable in that I didn't find myself tapping my foot (tonality not as good as with the BDT500's DAC), and perhaps most noticeably with transient triangle and cymbal sounds. Time to sell the DAC3.
3. My external Benchmark DAC1/HDR is the equal of the BDT500 player; or close enough that it's not worth worrying about.
4. Using a single 2' digital coax cable for the signal in S/PDIF format gives same result as with my external Bel Canto DAC3. Probably slightly worse with the 2' cable.
There's also a recent/short AVS thread on "Coaxial Audio: Special Cable?" at http://www.avsforum.com/avs-vb/showthread.php?t=1412447
My own personal preference for RCA interconnect cables (either analog or digital) is the reasonable http://www.bluejeancable.com/store/digital-audio/index.htm
(fixed address)
I see zero reason to spend more for an interconnect cable than the above no matter how into high end audio you are.
It isn't just the RCA connectors used, *everything* in the circuit affects impedance.
That ref that amirm gave is worth reading if only for the impedance match/mismatch explanation: http://www.positive-feedback.com/Issue14/spdif.htm
Edited by OtherSongs - 6/19/12 at 1:56pm
(fixed address)
