My last build was Aug 2007. I am very much behind the times and technology.
Some of the sites I used last time to get suggested component lists no longer seem to offer that
Any suggestions welcomed.
If you have a 120gb SSD and a second standard HD, does only the OS go on the SSD and you install all games and software on the HD.
I hope to go with an I5 or maybe I7, but need suggestion for good rock solid MB and aftermarked cooler. I prob won't OC, but reliability is paramount
thanks
Dan
thanks
Dan
