AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Expand/Collapse AVS Forum List Wonky
post #1 of 4
With FF, when I collapse 11 forums in the AVS Forum listing, then expand any one of them, ALL the collapsed forums expand upon immediate refresh.
One clue might be that it takes 2 clicks to expand a forum list... clicking on any one of the collapsed forums once does nothing, but that's the action that causes all forums to expand upon refresh... don't need to actually expand a forum list.
Edit: Happens only on the + icon, requires 2 clicks to change 1st one to -, and that 1st click is what's creating the problem (immediate refresh shows all/most collapsed lists now open).
After 1st click on + icon, 2nd click collapses that forum list and all others collapse with 1 click, but the "damage" is done with that 1st click.
Edited by wajo - 6/20/12 at 3:32pm
post #2 of 4
Have reported thus to be looked at.
Thank you.
post #3 of 4
I ticketed this for a fix, good catch.  It seems specific to Firefox.
post #4 of 4
Same thing happens with my IE8.
In both FF and IE8, after 1st click causes the problem, only way to get back to desired collapses is to expand them all, then start over collapsing.
A refresh gets most forums expanded then I can manually expand the rogue(s) that didn't expand to get ALL forums expanded for starting over.
  Back to Forum: Forum Operations Center
