Originally Posted by John Clark
Joe,
I checked O Remote, it looked great, had very good reviews, andI was all set to download it to my iPad2 for use with the 5010 in place of the woefully cheap and inadequate supplied remote. However, I discovered the fact that you must have the AVR networked to use it, and my router is three floors and about 85 feet away from the 5010's location. This is really unfortunate since I just can't stand the standard remote. I hadn't tealized how much this AVR's not having Air Play would complicate things.
I also really don't feel like dropping $250-300.00 on something like a Harmony 1100 remote just to be able to effectively use the receiver. I'm extremely happy with the sound quality, the amplification, the features, the Audyssey/XT32 of the 5010 and especially the 11 channel sound performance. It's just disappointing to run into an issue like this. Especially as I've not currently come up with any solution to resolve it.
John
Joe,
John
You can just get the WiFi adapter. If you want a wired Ethernet connection and have a cable TV/satellite/FiOS line ran to where your HT setup is located, you can get two MoCA routers and attach the receiver to your network this way. You can get two Verizon FiOS MI424WR MoCA routers on eBay for less than $100.00. What you would do is attach one router to your modem with an Ethernet wire, and also connect a cable TV line to it. The other router goes attached to the receiver via an Ethernet wire and it gets connected to your other router via the cable TV line.
I have the FiOS service with the 150Mbps/35Mbps plan and I get about 95Mbps down in the computers that are not connected to the main router. I have 4 MoCA routers and a regular router on my network. My FiOS TV and phone services are unaffected by the MoCA routers.
Edited by TazExprez - 9/15/12 at 4:10pm
