Originally Posted by
btinindy
True. Sometimes it is hard to believe some of the problems that these higher end receivers have. With all of the bells and whistles these boxes have in them, I realize that there will be some issues. I am most disappointed with the fact that the Onkyo HDMI board issues spanned at least two generations. Maybe too early to tell if more, though I have not seen this issue on 009 series and later. My neighbor has a 3008 and had his fail last month.
I would recommend anyone buying an Onkyo to buy the extended 4-5 year warranty
It will likely be your friend.... of .the six Onkyos I have owned over the past 5 years...only one of them has not needed warranty work...the PRSC885 preamp
Onkyo has completely replaced two receivers of mine with new units
People are starting to have issues with the XX08 series as your neighbor is.My 5508 has been to the shop for the famous "wire" issue and I had an HDMI hiccup last week. if you read the forums about two years( and generally after the warranty is out) is about when the HDMI boards like to go south. Go back to the forums with the xx5 models etc...same cycle
Bottom line... extend your warranty
I did on the 5508 preamp and both 5009 receivers...I feel good about getting my return back and then some
Warren
Edited by turnne1 - 2/3/13 at 10:32am
