AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Identity of Wall Mount
post #1 of 2
I installed this wall mount for my son-in-law several years ago. The middle articulating arm was removed as it was not needed. Now we are looking to match this mount with another. The only markings on it were apparently on the removed arm. Does anyone know the brand of this particular mount. TV size is 24"... 450
post #2 of 2
It might just be simpler to buy two new mounts if you want them to match.
  Back to Forum: Tweaks and Do-It-Yourself
