I have decided to move my indoor home office to a soon-to-be-built building where I hope to have less distractions from interruptions and noise.
Now, from what I have read on this forum... you are all soundproofing rooms within your homes. Is there much of a difference in trying to cut down sound getting into a stand alone room from the outside?
My contractor is great and willing to try some new things (and I keep telling him that with home theaters going into new homes.... he might want to read up on some of the techniques. But, he is great at what he does and slow to change things.
So, my questions for this group would be...
- What are 5 to 10 things that I could have this contractor do to cut out sound?
- Does anyone have leftover product (that might be suggested I use) that I could buy (at a great price)?
- I will have an AC unit in the room. SInce it needs to vent outside, what is the best way to soundproof that?
A little about the office.
* It will be roughly 11' deep by 17' long.
* There will be a 5' x 11' separate room (within the 11' x 17'). So, basically an 11' x 12' and an 11' x 5' room. The larger for the office and the smaller for a painting/testing room.
* It will be on a concrete slab.
* The back of the building will have concrete up about 4 feet (the area it will be built in is on a slope and the concrete will come up about 8" above the ground) at the back.
* There will be concrete on the sides, but it will step down with the slope of the hill and will end up at about 8" high in the front.
* He will then use 2" x 6" planks for the wall frames. I was thinking of having him use the staggered 2 x 4's on the frames. Good idea?
* I will have no windows in this building. I get distracted so easily that I want no sound or anything outside of a window to distract me. (Squirrel!!!!!)
* Solid entry door. Since I don't need as much soundproofing as a theater room, I will do just the one door, not double door.
OK, I hope that is enough information. I will continue to search the threads for ideas. I was just hoping to get 5 to 10 really important ideas in one place that I could show my contractor before he gets too far into the project. He is digging out the hole for the foundation tomorrow and also for the walkout basement door for my fathers apartment. So, anything I can get right away would be very appreciated.
Thanks you guys!!!!
Jeff
Night Sky Murals
Edited by NightSkyMurals - 6/23/12 at 3:27am
Thanks you guys!!!!
Jeff
Night Sky Murals
