To elaborate a bit...What I was getting at with the comment about $50 12's was that if you play the bang for the buck game you can end up with some sick things for cheap. John mentions using 4, 9mm xmax pro 18's against a single XXX. Of course the 4 pro 18's win overall. Is this a question? It is 4 drivers versus one. By that same token I'd take the 16 12's in the above example over the 4 budget pro 18's without hesitation. Something like 12-16 12" drivers against a single 18 is no contest every single time. However at some point you have to make the call on just how big of a system you can deal with though.
The question is if you can fit the 4, 9mm xmax, pro 18's do you go with those or do you need a driver with more displacement like 25mm for when you EQ the low end in which case you sac some efficiency? We can talk about the advantages of efficiency all day but I personally need the later.
I use 4 XXX's currently in 9 cubes each sealed with about 4500w per driver. One in each corner of the room. Truthfully this is more than enough. I do not have any issues with running out of headroom except when I purposely push the system to uncomfortably loud demo levels. When I do run out of headroom it is in the sub 25Hz range first due to the sub bass boosting done to get the response flat. The excursion gets scary and the drivers grumble first which tells me to back off a bit. I can make my coffee table literally jump around on the floor at certain frequencies under 20Hz at these types of levels. (Wood floor over crawl space). I never have issues in the range where the way more efficient pro drivers would have their 10dB advantage. Yes even with the incredibly innefficient XXX's, 4 of them and big amplification is still enough to do a lot of damage in a domestic environment such that I never find myself running into headroom issues in the music bass range.
Now I never claimed this bass system as "the best", or something to emulate or any of that. If I had it to start over again from scratch would I go with something else? Probably. Also my subwoofer section is far from complete anyway and I've been spending the last year trying to decide what to do with it to finish it off. Some of the DB testing is related to this search. See I built my enclosures with dual opposed either 18's or 21's in mind from the beginning and that is why there is a removable baffle on both ends. I had thought that I would replace the XXX's with a pair of 21SW152's or 21nlw9600's and get the extra 10dB of headroom in the upper bass plus perhaps a little extra displacement but after testing a couple of 21" pro drives it really does take 2 of them to almost equal the low bass output of one XXX. My favorite driver I have ever used probably is the big B&C BTW. Also those a very expensive drivers and I need twice the number of them to just maintain parity in the deep bass with what I already have and am happy with to begin with? Not to mention the biggest improvement is in a range that I don't currently have headroom or distortion troubles with anyway? That just seems like spending a whole lot of money for...? What I really need is even more displacement and if I can get extra top end at the same time, great. I thought I could re config the enclosures and go to 4 21's per enclosure but now we are talking crazy money. Not in the cards. Then I thought I already have 3 LMS's so I'll just sell the XXX's and use the proceeds to buy 5 more. Again that is a lot of work to sell the XXX's and recut the baffles and it still ends up costing a good chunk of money. Only a moderate gain in displacement. Meh...Then I thought about 8 Zv3's or 8 FTW21's but that has most of the same problems as the LMS route. Cost, work and having to sell the XXX's which I think will be a PITA.
Currently I'm leaning towards saying to hell with it and buying 3 more XXX's pulling the one wasting away in my garage from the ported enclosure and just slapping those 4 in with the current 4. It would be the least amount of work by far requiring only cutting the driver cut-out in 4 baffles and I would gain the most potential displacement. Not only that but even with the extra power from the amps I should at that point be amp limited everywhere. I will never have to worry about over excursion or damage to drivers ever. I do not see there being any headroom deficiencies in any realistic scenario if i go this direction either. Anyway that is the reasons why I ended up moving away from the high efficiency units for my HT sub bass duties in case anyone was wondering why I have ended up back with the inneficient boat anchors that I started with. One mans particular situation...YMMV and all of that.
40Hz and on up I'm a huge fan of the pro high efficiency drives and I think they beat the snot out of the innefficient car audio and consumer grade stuff, which is why you'll see me using big mains and big mid woofers. I bought in for 11 drivers in the AE deal. 9 are 4 ohm TD15M's with Apollo. The current crop of big pro woofers are closing the gap but still just don't quite have enough VD for the sub 30Hz freq's without resorting to large groups of them.
Oh and Scott....
4 2226's per main don't you think that is a bit excessive? You can't possibly need that. I've been running a pair of 4645C's which have 2 in each in a very large room at sometimes absurd levels and it is more than enough. Good god man. I'm only going to run a single 15" driver per main! Sell half of them to fund the finishing of the project.
Oh and Scott....
