AVS › AVS Forum › Audio › Soundbars › How Does a Sound Bar Work
post #1 of 2
Sorry, don't know much about them.
What connection do they use to go into a tv?
Is there two speakers inside the sound bar (left and right)?
Do sound bars come with a separate piece for bass?
Can you set a sound bar right in front of your tv stand or should it be mounted above the tv to the wall?
Will the sound still come out from your tv when the sound bar is on?
What are some of the lower cost brands that are still good quality? so I can look out for a sale.
thanks
post #2 of 2
Depends on the soundbar and the type of connections it has. Could be HDMI, digital, or analog.
Again, depends on the soundbar. They will have two or more speakers.
Some include subwoofers (wired or wireless), some don't.
Your choice
No, not if you set it up correctly.
thanks
Suggest you do some research to get a better understanding of soundbars and determine what is important to you. Try searching Amazon and sorting on price, then read specs and descriptions of those that fit in your budget range. After that, you can read threads here that are dedicated to those soundbars.
  Back to Forum: Soundbars
