AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Difference between 120 Hz & 240 Hz LED (native)?
post #1 of 3
Hello,
I am on the verge of buying the Samsung ES6800. However, one area of concern I am having is that this set is only 120 Hz native (not 100% sure but I thinks that's the case). Bearing in mind the set's steep cost, this was a bit of a let down.
My question is, is there any real benefit of having a 240 Hz screen vs 120 hz? Im not looking for the Soap Opera Effect in movies.
I understand the Sammy has a 500 Hz Clear Motion Rate (CMR) but that will induce the Soap Opera Effect. Correct?
post #2 of 3
If yoiu are not interested in motion smoothing to get the SOE and you are not interested in 3D the 120Hz is fine.
post #3 of 3
I believe the difference is about $600.- $800. but I could be wrong. rolleyes.gif
