Originally Posted by
simple100
great tread, thanks..
wound one be able to do a extra unit in this build, maby if you made all 3 compartments sealed, as one for each speaker unit Tweeter - extra 10"mid - 12 or a 15" bass unit.
how do you like thise vs your old, you old had 3 way or? do you miss that whit 2 way? and how it the tweeter handling voice.
Sorry for delay, simple100
I'll let the experts weigh in, but my understanding is that the SEOS wavguide and CD (compression driver/tweeter) mitigate the need for a mid speaker. The SEOS/DNA360 can reach much lower than a "plain old" tweeter, so you can achieve a flat response without adding a mid. At least that what this noob thinks...
As far my old speakers, they were Paradigm Titans (bookshelf two ways) for L/R and CC-170 v2 for center. The paradigms did me well, but I wanted an upgrade on power, presence, and clarity. I got all of that and then some with the SEOS build. As reference, I was leaning heavy toward a Klipsch setup, before I got bit by the DIY / SEOS bug.
Bottom line, I am extremely happy on how they turned out. We all have different starting points for reference, but at least for me it was night and day upgrade. I am missing absolutely nothing from the paradigms.
Does that help answer your questions?
