Just installed and configured the 6 zone Lync system from HTD.com.
Summary - Very impressed...works better than I thought.
Installed the system with 6 keypads and seven sets of speakers (one of the zones is pushing 4 speakers--and the amp specifically states it can handle the Ohms). Sounds great....a few comments:
If I were to do it over again:
Overall quite happy--and excellent value when compared to some of the high end stuff.
- The remote system where it will route to only to the emitter tied to the source is fantastic for multi DVRs in one closet
- The intercom works great (can turn "party mode" on to call all zones)
- MP3 via USB is a bit weak (plays in order, no real control), but it supports 8GB, and as long as you fill it with music you like, it's a good alternative
- Hooked up a cheap ir-controlled radio so I don't need to tie up a receiver as a source
- The network control unit (forget the name) is basic. allows for control and naming sources/zones.....but it's very utilitarian.
- I'd put the keypads in more natural remote-pointing spots, rather than natural "light switch on the wall" spots. I thought I'd be pressing buttons on the keypad more than aiming a remote....I was wrong.
- I'd run more IR receiver eyes beside tvs.
