AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 2312CI- No sound out of the speakers
post #1 of 6
Weird stuff... usually receivers are plug and play, but yesterday i finally got a chance to setting up the rest of my home theater up.
purchased the Denon 2312CI. i plugged in the HDMI cables and i see picture but there is no audio coming out of the speakers. Now i didnt plug in everything because im still trying to figure out which cable is which for the surrounds. But still i plugged in the 3 front speakers(Center and left and right).
I made sure the cables were in tight and the test tone showed that the speakers were plugged in but no sound is coming out. Im pretty sure its a stupid problem that im not noticing but any help pointing me to the right direction would be appreciated.
I didnt get sound from the internet stations as well which is odd.
any ideas please?
post #2 of 6
If you're not getting the test tones from the speakers and all are confirmed connected securely to each speaker post, then you likely got a defective unit. Try resetting the microprocessor (p. 144) as well as blowing compressed air into the headphone jack on the front panel.
Also note there is a dedicated thread for Denon AVR-XX12 owners linked in my sig.
post #3 of 6
test tones are working. I can hear sound from the 3 fronts(which i hate because i wish i could hear it for each individual one and not all at the same time)
just the audio isnt passing through.
do i need to configure the receiver to handle the audio via the hdmi?
post #4 of 6
HDMI connections should be plug-n-play right out of the box.
post #5 of 6
Got this fixed. Resetting the microprocessor helped.
But now im having an issue having the receiver decode the audio codecs from my PS3. Yesterday, i was playing Avatar and chose DTS MA. The receiver said BD Stereo.
Again, this is probably a noob issue but any help would be appreciated.
post #6 of 6
The PS3 needs to be reset as it was likely connected directly to the TV previously. While connected to the AVR with the AVR ON, press/hold the PS3 power on button for about 10 seconds until you hear a series of beeps. If you have a PS3(slim) model you can set it to "bitstream" otherwise if not, leave it in LPCM mode.
