AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz SR6006 vs. SR6007: Dual PLL Anti-jitter Circuit
post #1 of 6
Hi. The SR6006 spec sheet lists "Dual PLL Anti-jitter Circuit" as a feature, but the SR6007 spec sheet does not.
Spec sheet SR6006
http://us.marantz.com/DocumentMaster/US/SR6006_noxm.pdf
Spec Sheet SR6007
http://us.marantz.com/DocumentMaster/US/SR6007_0511.pdf
Can anyone confirm, with 100% certainty, if the SR6007 has the Dual PLL Anti-jitter Circuit?
Thank you
--jay
post #2 of 6
if anyone else is curious, Marantz responded:
Code:
Subject
Discussion Thread From Submitted Question
Response Via Email(NJ Customer Service & Support) - 07/03/2012 02:42 PM
Hello Jay,
The SR6007 does not feature a Dual PLL Anti Jitter Circuit as the SR6006 did. The SR7007 would be the only receiver out of the new lineup to incorporate that feature.
Thank you,
Technical Support / Custom Install
D&M Holdings NA
post #3 of 6
Hi JayNYC,
So what is the impact of that? What was this "Dual PLL Anti Jitter Circuit" for? Is it a great loss?
post #4 of 6
jitter is a major issue in digital audio; however, the benefit of this circuit will largely be system dependent.
post #5 of 6
So, if I understand well, this impacts audio quality? Or is it related to lip-sync and making sure audio and video clocks are accurately similar?
Thanks for your answer!
post #6 of 6
Hi I talked on the phone for a long time with technical support in the Netherlands. They said that only in the model SR5007 no clock jitter reducer, but it does not affect the sound in general.
