AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Polkaudio DSWmicropro 1000 any good
post #1 of 2
Has anyone heard and tried this sub polkaudio DSWmicropro 1000 what do you think of it. It says it is 1000 watts and 2000 watts peak.
post #2 of 2
Depends on your room size... Although it has a lot of power, the driver is only 8" with a 8" passive driver... You are not going to get much air movement with that. Polk specs the sub down to 27Hz so realistically, you are looking at a 30Hz bottom... Also the specs shows that the maximum output at low frequency levels is only 92dB... That is not much of an output for a sub.
