I recently replaced my Harmony 880 with a Harmony One to control only a few items (TV, Receiver, DVR, and PS-3 w/ harmony controller thingy). What I've always wondered about is WHY does it take so long for the whole process to turn off when the current activity uses the PS-3? I press OFF, and it will literally take 10+ seconds before stuff begins to shut down, and when it appears to be doing nothing after the TV and receiver are off, the transmit icon is still visible, then the PS-3 turns off last. Just FYI, the PS-3 is used 99% of the time as a media hub connecting to TVersity running on a networked server.
When I'm simply doing the activity called 'Watching TV' (doesn't use the PS-3), the TV and receiver will shut off within a second or two of pressing the OFF button. Easy, done.
Couple of questions:
Anyone have a similar issue as I've mentioned above? Any help is appreciated, thanks!
- Does the PS-3 really need to be turned off?
- Can I adjust PS-3 timings, or is there something going on that's needed and takes as long as it does?
