AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Xbox 360 not filling screen with Epson 5010
post #1 of 6
Just finished setting up theater with 5010 and 110" screen. PS3 fills up the whole screen but the Xbox 360 is only 4:3. I changed the resolution on the Xbox to 1080p but nothing changed. Thoughts? Thanks.
post #2 of 6
can't remember if there is another setting in the xbox for widescreen or 4:3, spend some more time in the menu.
Plug the Xbox into the PS3 input on the projector or receiver, to find the culprit.
post #3 of 6
XBOX is dependent upon source material. If you go into the menu (with the controller) while the movie/tv show is playing, and select the advanced options, you can cycle through native/ "fullscreen"/16:9, etc...
post #4 of 6
thanks, i'll try messing it with some more after work
post #5 of 6
started working, didn't change any settings
post #6 of 6
That's weird lol... At least its working though. I'm using an Epson 3010 with the xbox in my living room. All I did was set it to output 1080p and starting gaming, it was smooth as butter. Maybe it was just some strange anomaly...
  Back to Forum: Xbox Area
