Originally Posted by lockdown571
You're just not getting this. We're talking about sticking a blu-ray in your drive, the program doing everything for you, and then spitting it out. NO USER INTERVENTION. This is how My Movies for WHS works, although it rips the entire ISO. All of us know already how simple tsmuxer and makemkv are to use. The 2nd problem is the one that Derek K., myself and others have mentioned. Simply selecting the main movie is not sufficient for a number of blu-rays. There isn't always a single main movie. There are different versions, angles, multiple subtitle tracks, etc., and it's not always clear which one you want.
Originally Posted by olegy
How more automatic it could be?
In tsMuxer:
click one - drag the largest file into GUI.
click two - select blu-ray as output
click tree - press process
In BD rebuilder:
click one - select main movie only option ( unless previously selected)
click two - select a folder with a movie
We're talking two-three clicks total ( plus a couple of extra clicks, if you need to get rid of extra audio tracks and/or subtitles)
Unless you can find a voice activated program
, nothing else could be done in less than two-three clicks.
In tsMuxer:
In BD rebuilder:
, nothing else could be done in less than two-three clicks.You're just not getting this. We're talking about sticking a blu-ray in your drive, the program doing everything for you, and then spitting it out. NO USER INTERVENTION. This is how My Movies for WHS works, although it rips the entire ISO. All of us know already how simple tsmuxer and makemkv are to use. The 2nd problem is the one that Derek K., myself and others have mentioned. Simply selecting the main movie is not sufficient for a number of blu-rays. There isn't always a single main movie. There are different versions, angles, multiple subtitle tracks, etc., and it's not always clear which one you want.
I used my movies on my WHS to rip hundreds of BD. It was a great solution with very little intervention from me except to insert the disc and close the tray. And then to remove it. I would put three to five BDs in before work, and then before I went to bed I would do three to five more titles. Eventually I got them all done.
But now that my WHS is full and I also don't need to rip a lot of titles at once. I now use Ember to create the NGOs and to get the. Poster Art. Plus all my new rips go to my unRAID. I have not used My Movies since my WHS was filled up.
Sent from my HTC Rezound using Tapatalk 2
