AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo Unveils Three High-End A/V Receivers, Including New TX-NR5010 Flagship
Onkyo Unveils Three High-End A/V Receivers, Including New TX-NR5010 Flagship - Page 4
post #91 of 93
Originally Posted by discodol View Post
I so want 11.2 and unfortunately the 80.3 only does 9.2 but having the trigger out was more important to have since I use two external amps, one for center and one for front l/r.
When someone comes out with 11.2, trigger out, analog in, then I will be upgrading.
Which is why I put the pic of the Marantz 8801.
The Denon 4520 is the AVR version
post #92 of 93
Of course! I did not realize that until I did some research on the AV8801. It sounds awesome! Thanks for pointing it out!!
I would consider the Denon 4520 but it does not look like it has 7 channel analog inputs which is a deal breaker for me?
Is Marantz going to be doing an AVR version that includes 7 channel analog in?
If not I will go for the 8801 and just get some extra amps!!
post #93 of 93
The Denon 4520CI as well as the Marantz SR5007, SR6007, and SR7007 all have 7.1 EXT IN analog inputs.
