So my set up is nothing like any of yours, but I still need some help. So I have recently bought a polk series II center speaker and bookshelf speakers and they will be hooked up to my computer or TV since I run my movies and shows through my computer. I am inbetween these two receivers http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html and http://www.newegg.com/Product/Product.aspx?Item=N82E16882115371&cm_mmc=Semi%20Annual%20Sale%20%2712-_-488-_-N82E16882115371&nm_mc=Semi%20Annual%20Sale%20%2712. What cords and wires do I need to get for the rest of this set up and what differently do I need to do since my hdmi goes from my computer to my tv instead of the reciever.
Featured Stories
Related Forum Threads
- Denon AVR-1612 any Alternative to Airplay? Last post on 4/12/13 at 11:26am in Receivers, Amps, and Processors
- denon avr-1612 Last post on 2/27/13 at 7:28pm in Receivers, Amps, and Processors
- Denon 1612 AVR No Audio via TV Speakers on ARC Last post on 2/21/13 at 12:26pm in Receivers, Amps, and Processors
- Recommend a receiver for my home audio setup Last post on 2/11/13 at 8:07pm in Receivers, Amps, and Processors
- Help me pick my receiver - 7 choices Last post on 2/1/13 at 6:23pm in Receivers, Amps, and Processors
Almost done!
Gear mentioned in this thread:
post #2 of 5
6/27/12 at 6:19am
- cel4145
- Trader Feedback: 0
- online
- 7,826 Posts. Joined 3/2009
- Select All Posts By This User
I'd recommend the Denon 1612 because of Audyssey MultiEQ. Very good room correction setup software. Has bass EQ capabilities if you ever decide to add a sub.
Then, you should run an HDMI cable from your computer to your receiver, then an HDMI from the receiver to the TV. If you have your cable hooked to your TV, there's also probably some kind of audio out connection from the TV that can be connected to the receiver, too, (either RCA coaxial cables or digital toslink/optical). Then you will need speaker wire. 16 gauge should be fine.
Good place for decent cables and speaker wires is Monoprice.com. Better quality stuff than what you can get for cheap on Amazon or at BestBuy.
Sweet I was leaning towards the Denon anyways. By running these hdmi cords through the reciever will I still be able to get the image from my computer on my TV? or is that what you meant by "If you have your cable hooked to your TV, there's also probably some kind of audio out connection from the TV that can be connected to the receiver, too, (either RCA coaxial cables or digital toslink/optical)." Thanks for all the help.
post #4 of 5
6/27/12 at 6:45am
- Robert Cook
- offline
- 985 Posts. Joined 12/2008
I agree with cel4145--go for the Denon. You may want to get it here instead, though:
http://www.amazon.com/Denon-AVR-1612-Channel-Theater-Receiver/dp/B004U403WM
The price is basically the same with the free shipping, it is not a refurbished unit as far as I know, and it has a two-year warranty instead of one.
post #5 of 5
6/27/12 at 6:47am
- cel4145
- online
Yep. The receiver acts as a switching box. Run an HDMI out from it, and then you can plug as many audio/video devices into the receiver as you have inputs on the back. When you use HDMI, it will pass the video onto the TV. Or if you have a Wii or some other device with component video out, it can pass that video along to the receiver, too.
Meanwhile, if you happen to have cable company cable running to the TV with no cable box or you have a smart TV with Amazon Prime or Netflix, then you can still send audio from the TV back to the receiver. If you don't know what those are, then don't worry about it
- Almost done!
Currently, there are 1455 Active Users
(211 Members and 1244 Guests)
Recent Discussions
- › Official Samsung UNXXF7100 Owners Thread 25 seconds ago
- › NE Spring Speaker Shootout results thread - April 13, 2013 27 seconds ago
- › Hot Off The Press: The Latest TV News and Information 52 seconds ago
- › List of Reference Level, High Sensitivity & SPL Speakers 52 seconds ago
- › 5.1/2 AVRs 2 minutes ago
- › iView-3500STB DVR & Tuner Owners Thread 2 minutes ago
- › Official OPPO BDP-105 Owner's Thread 3 minutes ago
- › GTX 680 FTW Overclock help 4 minutes ago
- › The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's... 4 minutes ago
- › Suggestion on High-End media streaming solution!! 5 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BRAVIA KDL55HX850 55-Inch LED HDTV by Falgoonit
- › Marantz AV8801 by zuluwalker
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
