Originally Posted by dad1153
^^^ Are your parents cinephiles janus00? Just curious why you'd buy your folks a TV meant for movie lovers if they're primarily going to watch Dish or regular stuff unless it's the physical appearance (i.e. AVS' patented 'wife approval factor') matching your budget for their TV killing two birds with the same stone. Everything I've thrown at my XVT (1080i cable, SD DVD, amazon streaming, 3D Blu-ray, 1080p HD-DVD, etc.) looks fine except for the colors and blacks being a little less than perfect and washed out.
Hi, dad1153.
I'm worried for you that you feel your Black levels are so washed out.
I'm sure you've probably known this forever, but I just found out that you can send differently formatted HDMI signals to this thing from your devices; for instance, my Boxee Box can send RGB High, RGB Low, YUV444, and YUV422 as it's HDMI output choices. RGB Low is WAY WAY too light, and is extremely washed out. RGB High is the darkest black it seems, with YUV422 looking pretty good too. Maybe you devices are defaulting to an RGB Low or equivalent signal which is not best for the XVT.
Anyway, I hope you find some good settings.
In other news, I spoke with a Rep at Vizio yesterday about getting the latest Netflix version and running the internet streams in 3D. She assured me that a) no software update is scheduled for release, but b) Vizio has definitely NOT abandoned this product. (And then she informed me there was no way I would be able to update Netflix on the XVT outside of an XVT software update).
