I was using the 'keys' option within MPC-HC to map MPC-HC commands to my Harmony remote. Works really well. Select the function (play, pause, stop, etc.) hit the desired key on your Harmony remote and then that key will start the desired function while viewing a video in MPC-HC.
However, it didn't seem to work for a few commands, namely stats, control+j. Tried a number of different keys and while they would map in the options menu they would not bring up stats in practice. Any idea why? I could potentially go into my Harmony remote setup and create a sequence for control+j but wonder if there is a way to just map that function the same as I was doing the others.
