AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Cant get center channel to work on Denon reciever
post #1 of 5
Just got my Denon 2112 set up with my Polk 70's, Cs2. Sub is on the way. Last night tried for first time. The fronts sound great, but the center will not put out sound. During Audessy set up it emitts the sound and i get that staticy sound during center check, but when listening no sound. HELP.
Jamie
post #2 of 5
What dsp are you using ? Center won't get input for stereo, etc..
post #3 of 5
I am really not familiar with the system, and only hooked it up last night through the TV. I had it on satilite setup HDMI from the direct TV box to reciever, then HDMI from reciever to LCD. If this isnt what you are referring to let me know.
post #4 of 5
What does the front panel display on the AVR read? Stereo? If yes, press the "MOVIE" button on the remote and press DD PLII.
Also note there is a dedicate thread for Denon AVR-XX12 owner's linked in my sig. Review posts 3-6 for some helpful information.
post #5 of 5
I will try this when i get home, not at AVR atm. Thanks for the help, really apprieciated.
Jamie
