AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Music playing/streaming options without a computer (squeezebox, WD live, Nexus Q, PlayOn!HD)
post #1 of 5
I have an external HD full of ~300GB of music, organized via an iTunes library. I want to play the music through my HiFi receiver, but I don't want to spend hundreds of dollars on a new computer.
Can anyone recommend a system I can use, with streaming to other devices as a nice bonus option?
Some options I've considered:
- WD Live TV (I use for my TV set) has a nice USB slot, so I could plug in my hard drive and use the RCA jack to connect to my receiver. But that will have poor audio quality, it'd be a nightmare to organize and add music files using that UI and I don't think I can stream *from* WD Live (though maybe I can - I haven't looked into it).
- Squeezebox, Nexus Q, I don't have the ability to connect my existing music library.
- NAS, would cost >$200, plus I'd have to get some other device anyway, in which case I might as well buy a Mac Mini.
- AC Ryan PlayOn HD mini, looks ideal, except I live in the US.
It looks like ASUS and Masscool make media servers/players, but I don't know a think about them.
So, are there any good ~$100-200 options here?
post #2 of 5
You can connect an external USB drive to a Squeezebox Touch and use that as a music library.
post #3 of 5
You can , but I hear the performance is sketchy, works much better if you use another computer as the server. May work ok for small number of files.
post #4 of 5
That's true.
Up to about 10,000 tracks it's OK, beyond that I'd defnitely not recommend it.
A "real" server is definitely always better but my understanding was that that's not what the OP wanted.
post #5 of 5
Thanks for the advice.
I do have about 30,000 tracks, so it's definitely good to know about Squeezebox Touch's limitations.
So it sounds like a computer/server is really the way I'll have to go.
Any suggestions? I'm partial to the Mac OX and would be inclined to get a used mac mini for a couple of hundred dollars. But is there another option I should consider that can stream and run iTunes? Like some UNIX box running PLEX, which I've heard about but I've never used?
Thanks kindly.
